I just hooked up my cluster and my speed warning device started buzzing. I put 2 new gears in but couldn't find a few that needed to be replaced. I located the parts with FORUM help at a spedo shop. The shop recommended that they check the magnets and re-calibrate the speedo so they assembled the speedo. I think I tested the warning circuit at the speedometer when I got it back.
My question is: Is one of the speedo mounting screws supposed to be grounded? There is a small brass grounding terminal/strip, (about 7/16 x 1" with jagged edges) that I put under one speedo mounting screw. The AIM U15 A1 does not have much to look at!
Was that small ground terminal/strip supposed to be at another location?
Dom
Dom
Then I take another 2 before I get under the dash later in the day to reinstall the cluster.
