Have chance to pick up a set of NGK B6S spark plugs from a friend. I have a 63 L-76 in which I have always used AC-44 heat range plugs, be it AC or Champion. As best I can tell, by my cross reference chart, the B6 is the equivalent heat range. My question is does the "S" designate power tip like it did with the Ac's, and can/should I use them on my next plug change?
Stu Fox
Stu Fox
