dated bonding strips - NCRS Discussion Boards
  • Don H.
    Moderator
    • June 16, 2009
    • 2236
    I had heard that original bonding strips were sometimes dated. It made my day to find my lower right rear fender bonding strip and horizontal tail strip ink stamped May 10 1965 on my June 11 built convertible. My lower left rear strip is undated but still shows the tiny MFG embossed logo. (or is it MFC?)
    thanks doc. You get my age, you forget things. I knew that before I forgot it.
    • 11608
    Re: dated bonding strips
    MFG.
    Molded Fiberglass Boat Company in Ashtabula, OH.
    Robert Morrison, founder of MFG, convinced General Motors in 1954 to make the Chevrolet Corvette the first production automobile with a fiberglass body.
      • 3415
      Hi Don.
      NICE!
      When I see date stamps like the one in your picture I'm always reminded of the stamp the librarian used when we'd check books out to take home!
      • Bill W.
        • March 1, 1980
        • 2000
        Every body panel & bonding strip on my May 12 built St louis car had an ink stamp date including the many parts that make up the cowl panels and the under side of the hood and rear body panels .
        • Don H.
          Moderator
          • June 16, 2009
          • 2236
          yes, Alan, it sure does appear to be the very same ink stamp. Do people still go to libraries and check out books?
          • Leif A.
            • August 31, 1997
            • 3607
            Alan and Don,
            I think a more telling questions is does anyone even read books anymore?? Everything, it seems, is electronic anymore.
            Leif
            • Joe M.
              • February 1, 2005
              • 589
              dated section of driver's side rear edge side panel bonding strip dated March 23 1965 for 194675SI21736 FROM 1971.
              • Don H.
                Moderator
                • June 16, 2009
                • 2236
                thanks for adding that Joe,
                I like it.
                that's an early dated piece for a late June built convertible? Would that have been a Smith body?
                Joe,
                AOS bodies were constructed several weeks earlier (and will display a Trim tag with earlier body date imprint) than StL bodies were for a given assembly date. If your 21736 body was built in StL, likely it would bear bonding strips later than mine, ie mid to late May, rather than March.
                  • 3415
                  • Joe M.
                    • February 1, 2005
                    • 589
                    Bought that car for parts. Was originally a big block as evidenced by the rear sway bar and thicker front swaybar. big block accelerator rod and original driver side fender was drilled for the 396 tags. Not up on AO Smith differences but it also had undercar exhaust. No engine or trans or trim tag that I recall. When wrecked it had a small block. I may have some pics of the firewall and frame somewhere. Think the tach was a low hsp. Still have the dash somewhere.
                    • Stephen B.
                      • April 1, 1988
                      • 876
                      I just put the body to my 65 on a rotisserie and found a dated bonding strip I will try to post a picture in a few days.
                      • Don H.
                        Moderator
                        • June 16, 2009
                        • 2236
                        I just found a faint date on my back left vertical strip that throws my whole theory about the timeliness of the bonding strips to the body build date out the window. This one appears to say APR 26 1964. This one is a good year older than my car's build date.
                        • John L.
                          • February 20, 2009
                          • 186
                          Gents
                          This car was shipped the last week of April '65 (116117) AOS build (testing to see if I can still load a picture)
                          • George J.
                            • March 1, 1999
                            • 774
                            MFG.
                            http://www.moldedfiberglass.com/about-us/corvette-story
                            Pat,
                            Great video, thanks for posting!
                            George
