Mounting a '69-'75 15" dia wheel on a '65-'66 telescopic column - NCRS Discussion Boards
  • Douglas G.
    • April 30, 2001
    • 58
    Is it possible to mount a '69-'75 15" dia. steering wheel on a '65-'66 telescopic column. If so, what are the difficulties and
    what are the required changes or modifications? Thanks for any help,Doug
  • Russ S.
    • April 30, 1982
    • 2161
    Re: Mounting a '69-'75 15" dia wheel on a '65-'66 telescopic column
    Shouldn't be a problem. Just have to use a couple small washers on a couple screws to space out the offset spoke.
    • Jim R.
      • June 30, 2001
      • 643
      Hi Doug ,yes the washers will work without any modifications or the owner of the car could remove the hub and have it machined for the bottom spoke of the wheel it would then look like a 67 68 on up hub with the recess.
      Jim
      JR
