Re: Rear End lets go after only 300,000 miles !
Ed, just make sure everything is tight on the differential, especially the bolt on the pinion gear. If that comes loose and slides in you end up with Jack's problem. I had the same problem as Jack but not as bad. I just had to replace the posi. unit. Also, change the fluids.
If you look at post 21 in this thread, that is what happened to me.
