Attached are scans of Vol. 16:#1. The first two are of the one that lacks the "special membership edition" on the front cover, and has the ISBN number on the back. The second is, as I remember, what we received when we were subscribers to the Corvette Restorer back then. The last is the same as the second, but in the spiral binding. Who remembers how that all played out, and what the availability/sequence of these three books were?img309.jpgimg310.jpgimg311.jpgimg312.jpg
Restorer, Vol. 16#1 Questions
Re: Restorer, Vol. 16#1 Questions
Mike,
You are correct about the second example being what we received as members back in 1989. I believe the other two are versions that were available through the NCRS store. IIRC the spiral bound version was second and the bound version showing the ISBN # with a price on the back cover was the latest version. You might check with the Mortimers and see what their recollection is because I have never owned an example of the bound priced example you showed.- Top
Attached are scans of Vol. 16:#1. The first two are of the one that lacks the "special membership edition" on the front cover, and has the ISBN number on the back. The second is, as I remember, what we received when we were subscribers to the Corvette Restorer back then. The last is the same as the second, but in the spiral binding. Who remembers how that all played out, and what the availability/sequence of these three books were?[ATTACH=CONFIG]56996[/ATTACH][ATTACH=CONFIG]56997[/ATTACH][ATTACH=CONFIG]56998[/ATTACH][ATTACH=CONFIG]56999[/ATTACH]Attached Files- Top
