Paint recommendation for '96 LT1 exhaust tips - NCRS Discussion Boards
  • Paul S.
    • December 13, 2013
    • 83
    I just cleaned up the mufflers and exhaust tips for my '96 CE LT1 and painted with Rustoleum 2,000 degree flat black paint. It looks great but I think the finish is too flat. Any recommendations for the correct paint to use for a finish coat? Thanks, Paul
  • Pat F.
    • April 1, 1981
    • 852
    Re: Paint reccomendation for '96 LT1 exhaust tips
    Paul, I sent you an email re this issue. This was discussed previoulsly on this Board.
    PAT, Central New Jersey and Florida Chapters
    • Paul S.
      • December 13, 2013
      • 83
      Thanks Pat, I just saw your latest Email. I'm still learning how to correctly navigate the Advanced Search. Paul
      • Ed N.
        • May 16, 2010
        • 990
        Pat, can you send me what you have on this topic?
        Ed
        Ed Nieves
        NCRS #51799
        • David K.
          • September 30, 1979
          • 238
          Oh come on Pat, share with your friends. We all want to know
          Dave King
          • Jim T.
            • March 1, 1993
            • 5351
            I need to touch up my 1996 LT4's exhaust tips and mufflers, what type of paint are you going to use next Paul?
            • Pat F.
              • April 1, 1981
              • 852
              Ed and Dave, I sent you the same information I sent to Paul. Too much to put on the Board.
              Jim, do you want the same information?
              • Paul S.
                • December 13, 2013
                • 83
                Here is a picture of the exhaust tip just painted with paint that was recommended by Ed Nieves. I think it came out just right. Thanks for every ones help. Paul
                • Pat F.
                  • April 1, 1981
                  • 852
                  Alright Ed, what did you use for the tips?
                  • Pat M.
                    • April 1, 2006
                    • 1575
                    84-96 Service Bulletin 33-17-01A described peeling paint from 93-96 mufflers. When I noticed minor peeling on my 96 I called my local dealer and he was told to order Indy Sales & Service Touch - Up Sprays Industrial Finishes Paint - on the label it reads "KB-318-HHHS Black TU 07/15/2."
                    This rattle-can paint touched up my chips, and blended in, perfectly. My only complaint was it literally took several weeks to fully cure, and in the meantime it attracted a small amount of dirt/debris when driving - but that was years ago and I'm still very happy with the results today.
                    • Ed N.
                      • May 16, 2010
                      • 990
                      Pat, the paint we used was VHT SP671 (satin black). It goes on very even and levels nicely. I've experimented with a few and I think this one gives the closest correct appearance. I would use the same paint for the muffler, but just over-spray or lightly mist coat the very top section. Just my two cents.
                      Ed Nieves
                      NCRS #51799
                      • Pat F.
                        • April 1, 1981
                        • 852
                        Ed, thanks for the information.
                          • 43193
                          Pat------
                          Slow drying paints can be extremely inconvenient. However, slow drying paints are also the most durable.
                          • Pat M.
                            • April 1, 2006
                            • 1575
                            Re: Paint recommendation for '96 LT1 exhaust tips
                            Pat------
                            Interesting Joe, I didn't know that. Well, this paint must be really durable.
                            • Ed N.
                              • May 16, 2010
                              • 990
                              If you are looking for durability, try the POR-15 semi-flat (just make sure it's sprayed). Still has a fairly correct looking appearance and it's super tough.
                              Ed Nieves
                              NCRS #51799
