Re: Engine Block Testing
The machine shop wasn't lying to your friend. Parts used to be hot tanked in caustic soda back in the day. You counted on a set of cam brgs if you had a block tanked because it would eat the bearing material off the backing. Aluminum parts couldn't be tanked, they'd dissolve in the tank. If there was paint on the part when it went in, there was none when it came out. Parts looked mostly like new when hot tanked.
Parts are no longer cleaned like that. They are not submersed, they are washed in a wash cabinet that works like a dishwasher and uses hot soapy water. The detergent is environmentally friendly and bio degradable. Safe for aluminum. Will not remove the paint, never mind the scaled rust inside the water jackets. You're lucky if it makes it into the cooling system. The washers must have an oil skimmer to recover the oil/grease that comes off the parts. While the soapy water can be easily disposed of, the crud that settles in the bottom of the washer and it's tank must be disposed of in an environmentally acceptable manner.
It's a whole different world out there.
I took a crank that had rusted sitting in the trunk of a car into a machine shop. He said he could turn it, but had no way to remove the rust. If I brought it back to him cleaned of the rust he would be happy to do it.
So, if you want your block nice and clean inside, you'll likely have to that part yourself. Plug all the cooling system holes and fill it with a muriatic or phosphoric acid solution. Then deal with disposing of your used acids.
If the engine had run water or the coolant badly neglected you will have to remove the frost plugs and physically scoop the crap out before you try to clean it. I've removed frost plugs where there was a wall of rusty crud behind them. A full cooling system and nothing comes out when you remove the drain plugs. The bottom 2 inches of the block filled with crap.
Where the machine shops are negligent is in explaining all this when they take a badly rusted engine in for work.
Steve.
BTW, photos 1 & 2 show nice fresh carbon in the exhaust crossover. A likely product if you run headers or, as I've read on here, wire open the heat riser valve.
Steve.
At least he was consistent, potentially ruining TWO rare blocks.
