Screw Hole Repair - NCRS Discussion Boards
Screw Hole Repair
  • Terry D.
    • May 31, 1987
    • 2690
    Screw Hole Repair
    Several years ago a guy was selling a door panel screw hole repair kit that consisted of plastic inserts that you had to make a square hole for. They were just like some license plate plastic inserts only smaller. I believe he also did steering wheel restoration. If someone could direct me to this person I would greatly appreciate it.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: Screw Hole Repair
    those plastic inserts force the door panel to protrude towards the center of the cockpit and an observant judge can see the inserts and see that the door panel is not in its original position. i tried them about 30 years ago and didn't care for them. instead, i cut a piece of 18 or 20 gauge sheet metal into multiple 1 1/2 " squares, then pop rivet them to the backside of the door's framing. this will never pull the trim screws. mike
    • Terry D.
      • May 31, 1987
      • 2690
      Thanks Mike but I'm not using them on door panels, I found out the hard way just like you that they are not the best solution for door panels. We are working on another project and I think they will be the best solution for it.
      • Bill W.
        • March 1, 1980
        • 2000
        Mike with the new 3M epoxies I would bond the metal to the inside of the door and not worry about the rivets showing . some of them dry in less than 1 minute .
        • Mike E.
          • February 28, 1975
          • 5134
          That was Joe Calcagno wasnt it?
          • Edward B.
            • March 29, 2013
            • 691
            A CHEAP alternative (if it's hidden) is the old paperclip trick. If the hole's not too far gone, you can unfold a paperclip, bend into a U shape and insert it in the hole. The thickness of the paperclip takes up just enough room so the screw now has something to grab onto. There are a few sized paperclips available, anywhere from very thin to fairly thick, so you should be able to find one that suits you. I've been using this trick for almost 50 years!
            Ed
            • Steve G.
              • November 24, 2014
              • 411
              You can buy those plastic push in nuts in various sizes at most autobody supply shops.
              • Frank D.
                • December 27, 2007
                • 2703
                I have one of those square hole repair kits that I bought several years back ... they are very good ... much better than the plastic wall anchors some use. The flange on them is very thin....I don't see how anybody could detect them behind a door panel. If they can they you didn't use them correctly. I think I got them off eBay.
                • Joe M.
                  • February 1, 2005
                  • 589
                  use j-nuts
                  • Terry D.
                    • May 31, 1987
                    • 2690
                    Thanks Steve and Mike I will check those out. As I stated before I'm not trying to fix a door just want to find those push in nuts!
                    • George R.
                      • February 1, 2001
                      • 19
                      Search eBay for "Dodge truck grill nuts". Year range from about 1986 through 1990. Probably just what you're looking for.
                      George
                      • Joe M.
                        • February 1, 2005
                        • 589
                        j-nut hole repair in a 61 door
                          Corvette Central has sold a "hole repair kit" for many years that includes ten pre-cut steel panels with rivet holes already pierced, and 20 pop-rivets to install them with; you put them on the back side of the fiberglass part you're working on, then you just drill the size hole you need in the steel panel and you have a solid attachment.
                          • Brian M.
                            • February 1, 1997
                            • 1837
                            Fill the oversized hole and surrounding area with a glue gun.
                            • Terry D.
                              • May 31, 1987
                              • 2690
                              LOL For the second time I'm not trying to fix a door, I just want to find those push in plastic nuts. lol
