Face Plate under radio in 1959 corvette - NCRS Discussion Boards
  • Tom B.
    • September 12, 2014
    • 10
    I am attempting to install a new face plate below my radio in my 1959 Corvette The Defroster knob comes off
    with a screw the temp and air knobs do not the replacement knobs have threads but the existing knobs will not
    unscrew Also I do not see how to get the Bezels out Any suggestions?
    Tom Brennan
  • John F.
    • March 23, 2008
    • 2395
    Re: Face Plate under radio in 1959 corvette
    They are both push-pull cables. They do not come off. Do you have an AIM? A schematic is in SECT 101 Sheet 3.00. The "air" cable goes thru the firewall to the control lever out in front of the heater where the fresh air hose attaches. The "temp" cable goes up to the control valve where your heater hoses come thru the firewall above the passengers feet. Both of these knobs are held to the face plate by a lock washer and nut on the back side. In effect you need to disconnect the ends of the cable and pull the whole cable thru. You will need to lay on your back with a bright led light and trace it along to see where it goes. Hope this helps.
    • Tom B.
      • 10
      thanks very much John Much more difficult than I thought I think I will just clean the existing
      face plate the best I can and leave the clock in that does not work thanks again
      Tom Brennan 60456
      • Mike E.
        • February 28, 1975
        • 5134
        All you need for the clock is to push it in and rotate it. There's only one electrical contact on the back.
        • Bruce B.
          • May 31, 1996
          • 2930
          If you do decide to remove the cables be very careful with the top fan switch.
          The resistor on the switch is easily damaged.
