C2 electrical fault - brake light and indicator 1965 - NCRS Discussion Boards
  • Keith W.
    • June 30, 1998
    • 375
    Guys hope you can help or can point me in the right direction, took the car for an MOT test which once passed allows you to drive on the UK roads.
    The rear left hand side brake light does not work, ( indicator works bulb works when you switch the lights on) I've checked the bulb all OK I took the light out and cleaned the earthing wire, also checked the plastic plug all OK - any pointers cheers Keith
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: C2 electrical fault - brake light and indicator 1965
    Keith,
    Does your brake lite work on that side?
    Dom
      • 6940
      Keith, The stop lamp wiring for both left and right run through the directional switch, Sounds like a switch problem, Take a look under the dash and make sure the wiring connections all look good first, sometimes things like wires get pushed out of the plastic holder.
      • Donald O.
        • May 31, 1990
        • 1580
        Your tail/brake lamps two filaments and either can fail while the other will work. Try a new brake/tail lamp. The two loacating or lamp base retaining pins are not at the same distance from the base bottom, they are offset to allow for only one way insertion. There are also two hot nubs (contact points) on the lamp base bottom, one for tail lamps and one for brake lamps.
        If the lamp is new and good, use a DVM to see if there is voltage at both pins
        Pull the light switch to ON and check for voltage at both contacts in the socket, it should only be at one.
        Have someone step on the brake and check for voltage at the other contact.
        If NO voltage on the brake contact in the socket trace back to find the open in the brake light circuit
        DonO
        • Keith W.
          • June 30, 1998
          • 375
          Dom - No brake light only indicator and when you pull the light switch on
          • Domenic T.
            • January 29, 2010
            • 2452
            QUOTE=Keith Willcox (30641);732233]Dom - No brake light only indicator and when you pull the light switch on[/QUOTE]
            Kieth,
            check the bulb and see if the brake side is bad. then take a test lite and check the socket with someone operating the brake. With the lights on uou should lite the test lite at both terminals.
            If only the tail lite and no brake lite, then follow the instructions on the earlier posts.
            DOM
            • Keith W.
              • June 30, 1998
              • 375
              Thanks guys gives me something to do tommorow if the snow keeps off
              Cheers Keith
