Frame Serial Number on a 62 - NCRS Discussion Boards
  • Patrick S.
    • January 1, 1988
    • 209
    Does anyone have a "fairly close" location for a 62. I know it is suppose to be "under your butt" on the drivers side, but I have looked extensively and cannot find mine. The frame underwent sand blasting when it was restored and I hope they did not blow the number away. A picture would be great!
  • Joe M.
    • April 30, 1990
    • 1338
    Re: Frame Serial Number on a 62
    Sand blasting should not have "blown the number away." The force required to strike the two sets of S/Ns created two slight indents in the top of the rail; closer to the outside edge of the rail than the center. If you run your fingers along the top of the frame rail under driver seat area, you should be able to feel the indents. The indents are subtle.
    • Bill O.
      • April 1, 2006
      • 542
      This might help, at least in its likely position relative to frame rail width.
      • Jim D.
        • 2882
        These are the numbers on my 1960 after sandblasting and paint (highlighted in chalk). You can see the indents that Joe is talking about.
        • Patrick S.
          • January 1, 1988
          • 209
          I found my frame numbers under the body mounting pad at the joint in the body in front of the seat. The stamp is faint and the last two numbers do not show.
            It's directly across from the center of the "X" intersection in the frame, and a second impression should be found about 12" forward of that one.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11302
              These might help too.....THis, a '59 but the same on '62. You can "feel" the depressions from the stamp machine with your eyes.
              Rich
              And here with the body on, on a different 59, mine....
