I went through everything on my '66 a final time in preparation for my PV for next weeks Florida Regional and have a couple of questions on the function of heater and fan control.
The PV manual and the owners manual both state that the "AIR-PULL-DEF" knob is the air "on and off" control. Doesn't this knob just control the distribution of air between the floor duct at the rear of the console and the defroster. It doesn't really have anything to do with the air being on or off does it?
When and how should air come out of the sides ducts that are on the side of the console?
The manual also talks about that the "AIR-PULL-DEF" knob must be pulled to the detent position or further before the heater will operate. Does that mean that the fan will not operate with this knob in the fully closed position? What happens when this knob is fully closed and the fan is on? Do you not get any air flow and if you do where should the air come out at?
I also can't feel a really defined "detent". Is this common? How far out do you have to pull the knob to feel the detent?
The "FAN-TEMP-PULL" knob does nothing more than control fan speed and air temp, correct?
Thanks for your help.
