Putting chassis back together and just installed the 9 leaf rear spring. I bought the spring new, took the holding clips off the ends and painted the leafs the correct color and put back together without the clips reattached. I noticed when I attached the ends of the spring to the trailer arm that the 7th and 8th spring is sitting slightly back (quarter of an inch) from the other springs. Is this a concern? The spring is 2 1/4 wide and I am using the 9/16 bolts so there is no gap at the diff end cover. Will these springs align themselves when there is full weight on the car and I torque the 4 bolts?
67' 9 leaf spring with 2 misaligned springs
Re: 67' 9 leaf spring with 2 misaligned springs
Did you check that the 9/16" bolts are the correct length? The height of the replacement spring may be lower than the original and the forward bolts may be bottoming out. Also some suppliers bolts are too long and need to be shortened for the forward position holes.Putting chassis back together and just installed the 9 leaf rear spring. I bought the spring new, took the holding clips off the ends and painted the leafs the correct color and put back together without the clips reattached. I noticed when I attached the ends of the spring to the trailer arm that the 7th and 8th spring is sitting slightly back (quarter of an inch) from the other springs. Is this a concern? The spring is 2 1/4 wide and I am using the 9/16 bolts so there is no gap at the diff end cover. Will these springs align themselves when there is full weight on the car and I torque the 4 bolts?- Top
Did you measure the depth of the front holes in the case to insure the bolts are not too long? It's possible the bolts feel snug but may be bottoming out in the case leaving the spring able to twist.- Top
Here are some pictures of the spring. The 7th and 8th leaf are pushed backward by .25 inches. All the leafs are in good alignment at the center of the spring. It is just the last outer 3rd where the leafs start to slide back.
image2-2.JPGimage1.JPG- Top
