65 door panel clips & screws question - NCRS Discussion Boards
  • William S.
    • March 1, 2002
    • 55
    Are the long screws correct for attaching my 65 door panels under the arm rests?
    Are the short screws correct for attaching the door panel clips? My Assembly Manual shows hex heads.
    Also, what is the correct finish for the door clips?
    Thanks for your help.
  • David T.
    • April 30, 2006
    • 46
    Re: 65 door panel clips & screws question
    Yes the shorter screws are for the door panel clips, which according to 66 judging manual can be either cadmium or zinc plated. There should be 5 clips per panel. The screws under the arm rest are cadmium or zinc plated Fillister head Phillips machine screws with flat cadmium or zinc plated washer.
    • Russ S.
      • April 30, 1982
      • 2161
      The clips have a dark plating on them probably Black phosphate. They are some where in between black and grey.
