I started a "rebuild my brake system" project which has now grown into a wholesale restoration of the rear suspension. The rear splash shields were in rough shape, and to replace them requires removal of the rear spindle which pretty much requires removal of the trailing arm. After wrestling the trailing arm out, I went to remove the spindle, what I found on removal seems unusual.
The spindle bearings had the normal spacer and shim between the inner and outer bearings. Strangely - I found another shim between the inner bearing and the spindle flange. Prior to removal - there was very little play, but if I were to reassemble with only the original spacer and shim, I would have at least .050 of play. I am thinking that the added shim between the bearing and flange was someones innovative idea of a "shortcut method" (to not have to fit the correct size internal shim) and yet only seat the bearings once. It seems to me that the inner bearing would not be seated properly this way - but maybe this is no big deal for practical purposes.
Is this something that is commonly done?
