The rear deck protector on late C4 convertibles (I think 94 to 96) is protected by a clear film similar to this stuff:
The GM part (12524512) pictured below has long since been discontinued and I have had no luck finding one. None of the usual suspects sell anything close to the original. They're all "static cling" garbage.
Has anyone been able to recreate these? I would try creating a pattern from what is left of my original but I think we all know how that would turn out.
If I could find a NOS replacement like the one pictured above, I would take it to a metal working shop and have them make a pattern from 1/8" aluminum and use it to cut replacements using the Scotchguard film, which leads my to my next question: does anyone know the mill thickness of the original GM material?
Thanx
If I could find a NOS replacement like the one pictured above, I would take it to a metal working shop and have them make a pattern from 1/8" aluminum and use it to cut replacements using the Scotchguard film, which leads my to my next question: does anyone know the mill thickness of the original GM material?Thanx
Woo Hoo!! It was die cut with no boarder so it's unused dimensions provide the exact pattern for cutting a copy from thick mill 3M Scotchguard material. Also the paper backing will serve as a pattern for years to come.
