tripower 69 vs 67 intake HP differenece - NCRS Discussion Boards
  • Michael F.
    • 745
    what was the real horse power difference between a 68/69 435 and a 67 435 car.
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
    Re: tripower 69 vs 67 intake HP differenece
    Michael------
    Who knows? However, I expect the difference was not, at all, appreciable. The only differences between the two engines were:
    1) the 67 manifold was slightly higher rise; the 68-69 manifolds were reduced slightly in height for hood clearance;
    2) for 1967 only California cars were equipped with AIR; for 1968-69 all were equipped with AIR. However, the L-71 was always rated at 435 HP regardless of whether AIR was installed, or not.
    • Michael F.
      • 745
      Joe, with the shorter intake do you think you would loose any power in upper rpm range??
      Michael
      • Steve B.
        • March 1, 2002
        • 1190
        My guess is that the 67 high rise intake would make about 15 more hp at high rpms than the 69 intake.
        • Ralph P.
          • February 1, 1990
          • 253
          When did the open-chamber heads appear & didn't this make a HP difference?
          • Patrick B.
            • August 31, 1985
            • 1986
            The second design L-88 heads which first appeared on the ZL-1 aluminum 427 in January 69 were open chambered, but they were never used on a 427-435. Even the 69 L-89 427 435 continued to use the first design closed chamber aluminum heads after the L-88 had been changed to the open chamber aluminum heads. GM never developed 11:1 compression pistons for the 118 cc open chamber heads, and ,yes, the open chamber heads did increase power over the closed chamber heads in the L-88.
            • Mike F.
              • April 25, 2011
              • 668
              A little off topic, Corvette Fever, Jan. 2000
              • Steve B.
                • March 1, 2002
                • 1190
                That's about right for an L72 with side exhaust, the mufflers were very restrictive. An N11 set up would yield much better results.
