Clock Bulb Size - NCRS Discussion Boards
Clock Bulb Size
  • David R.
    • November 1, 1996
    • 31
    Clock Bulb Size
    I'm finishing up working on a 61 corvette and was putting light bulbs in their sockets. The owners manual says the clock should have a 57 bulb but the socket on the clock is to big for the base of the bulb. The bulb kit I have says to put in a 67 bulb. Does anyone know the correct size bulb that should go in the clock? I was wondering if it has the wrong socket end for the clock. Thanks ahead of time for any help.
  • Donald O.
    • May 31, 1990
    • 1580
    Re: Clock Bulb Size
    My information says it should be a #67 lamp.
    DonO
    • Pete P.
      • March 1, 1992
      • 103
      Re: Clock Bulb Size
      I have a 60 clock that I just had repaired and I guess I'm in the same boat as David. The Owner's Manual (page 80), says the clock has a #57 bulb, 2 candle power which has a smaller diameter socket. Don, what other reference did you use?
      Pete
      • David Z.
        • April 1, 2002
        • 181
        Re: Clock Bulb Size
        Doc Rebuild diagram shows #67 bulb for the clock.
        Dave Z
        Dave Zuberer
