Does anyone have a photo of the nut(s) that mount the horn relay to inner fender. In the AIM UPC 12 A8 shows part #3876130. Mine looks to be mounted with a rubber washer and a nut with rubber on it. AIM not showing any type of washer and nut looks diff. Thanks in advance
72 horn relay nut
Re: 72 horn relay nut
Here is the original horn relay on my 72. The nut is a self locking nut
EdEd DiNapoli
CNJ Chapter Past Chairman/Co Founder
1972 Targa Blue Coupe, Original Owner,
Duntov Award, Sam Foltz Award,
Founders Award, NCRS Gallery VIII
2011 Corvette Convertible
NCRS Presidents Award 2014- Top
I think he's referring to the two screws that actually mount the relay to inner wheel well. The two bolts thread into rubber (with a metal threaded insert) "well nuts". As the mounting screw is tightened into these, the rubber portion expands gripping the hole in fiberglass. At least on 72-73's
1973 LS-4 454 coupe owned 24 years
1996 LT-4 CE coupe
Victory Hop Devil Ale- currently on tap!- Top
Ken------
The GM #3876130 is a rubber well nut with a brass insert. It was widely used for horn relay and voltage regulator attachment. It's discontinued but there are many for sale on eBay.In Appreciation of John Hinckley- Top
