1962 Corvette Blackout procedures, areas and paint questions - NCRS Discussion Boards
  • Dino L.
    • February 1, 1996
    • 694
    Does anyone have a paint code for the semigloss black paint used under the hood and engine compartment? Possibly a PPG/Ditzler code?
    When the car is painted Tuxedo Black, does the front bumper openings and side fender grill trim ledge get painted blackout color or do they remain Tuxedo black.
    I have the following areas listed for blackout:
    underside of hood (JG depicts break lines/masks well)
    engine cowl and inner wheel wells
    behind front grill opening
    behind front bumpers openings below headlights
    Inside ledge of side fender chrome trim area, small strip both sides
    inner wheel wells
    I presume the trunk gets painted completely Tuxedo black, bottom, sides, and interior trunk lid....(black interior)
    Missing anything?
    Anyone who has a black bowtie car or researched this, I would greatly appreciate your comments.....thank you
    Dino Lanno
  • Edward L.
    • 278
    Re: 1962 Corvette Blackout procedures, areas and paint questions
    Dino:
    I'm sure I will forget some items, but here it goes:
    Use Krylon #1613 Semi-Flat Black
    The entire engine compartment received black-out. Items that were in place prior to the procedure are as follows:
    Wiper plate
    Hood latches-male and female
    Hood release cable and brass stops. There may be some disagreement on this-trust me they were there.
    All wiring clips
    Area behind grill
    Inside cockpit:
    Area above firewall insulation. Insulation will also have a trace of paint.
    Hood release cable near firewall will also have some traces of blackout
    Ed
