1967 cylinder heads - NCRS Discussion Boards
1967 cylinder heads
  • Donald O.
    • May 31, 1990
    • 1580
    1967 cylinder heads
    On a 1967 327350hp what size is the chamber?
    In trying to select the closest match to the domed OE for the 11:1 ratio for a restoration rebuild, all of the parts offerings will give a ratio with a value in CCs; examples:
    Kieth Black
    Chevy 327ci Hypereutectic Pistons Solid Dome .100''
    4.030'' Bore (+.030'')
    Use w/5.700'' Connecting Rod & 3.250'' Crank Stroke
    Comp. Ratio: 11.3/58cc; 10.7/62cc; 10.5/64cc; 9.1/76cc Head
    Speed Pro
    327ci Stock Type Piston, .030'' OverborePiston Dia: 4.030''
    Piston Top: .125'' Dome with 2-Valve Reliefs
    Pressed Pin
    Comp Ratio: 10.35:1 w/64cc Head
    Ring Grooves: 5/64'', 5/64'', 3/16''
    Both CRs are as measured with the 0.040 composite head head gasket, not the 0.015 steel shim OE type.
    So what did the General use on the 1967 L79 for the heads?
    DonO
  • Patrick B.
    • August 31, 1985
    • 1986
    Re: 1967 cylinder heads
    1967 327 heads are 462 castings that have 64 cc chambers.
    • Gene M.
      • April 1, 1985
      • 4232
      Kieth Black
      Speed Pro
      Pressed Pin
      DonO
      The General used steel shim gasket. But I think GM was optimistic about the 11:1 compression as most head and piston combo are far from optimal in achieving it.
