As part of my trailing arm rebuild project I painted my calipers and replaced the bleeder screws and plugs. Although I used gravity bleeding before I decided to try it with a mityvac this time. So in trying to follow the mityvac procedure I've found that I cannot get the mityvac to hold vacuum unless I replace the new bleeder screw (stainless steel purchased from Corvette Central) with the old bleeder screw. When I use the new bleeder screw the vacuum leaks down very quickly. The two look basically the same but it appears the new ones are not fully seating and I've tried snugging them up tighter but to no avail.
Anyone had a similar issue? Just curious, most likely I'm going to simply punt and put the old ones back in and be done with it.
I would had preferred to not use SS but most places I checked only had SS.
Jack
Jack
