1963 1964 Ignition Switch Lamp Assembly - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    A friend is sending me this lamp assembly from his buddy's 1964 Corvette that needs some help. I haven't seen if reproduced.
    I offered to replace the gray wire and install the correct connector. I don't have a photo of this part from my '63 in my files.
    Would anyone have a moment to measure the gray wire length and the plastic connector housing type used and if male or female terminal? A picture would be ideal too.
    I have old harness connectors and replacement terminals here so I can fabricate it.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: 1963 1964 Ignition Switch Lamp Assembly
    For reference and future interest.....
    The gray wire is part of the harness. There is no connector. Frank D sent me a picture of his from his coupe, and I found one on the Corvette Central site.
    I repaired the socket terminal, reattached a new wire and it can now be spliced into the harness bundle as originally done.
    Ref pics.
    CC harness showing the lamp plate assembly at the bottom.
    1963 AIM.....no connector.
    Repair. Note the tab holding the plastic insulator in place. I opened the copper contact and soldered a new wire in place.
    P3060012.jpgP3060013.jpgP3060014.jpgP3060015.jpgP3060016.jpgP3060017.jpgP3060018.jpgP3060019.jpgP3060020.jpgP3060021.jpg
