Where can one find an original 63 spare tire lock? Thanks in advance
1963 Spare tire lock
Re: 1963 Spare tire lock
Another excellent source is Gary Beaupre. Gary is also an NCRS member and an NCRS Restorer contributor, and has a small website that has these locks and other Corvette stuff. His website is http://garybeaupre.home.comcast.net
Larry- Top
IIRC there is more than one type in '63 and the weep hole and other factors determine the correct item. Some have a foam vibration damper; bottom lock in the picture.
I got mine from: jmbensko@q.comAttached Files- Top
- Top
Frank,IIRC there is more than one type in '63 and the weep hole and other factors determine the correct item. Some have a foam vibration damper; bottom lock in the picture.
Yes there are two different styles for 63 and two other styles for the remainder of the C2 era. And to complicate things, as of the past year or so there are now repro locks being sold, which, close-up, are detectable as repros. Some judges who haven't studied original locks might not notice the differences, but side-by-side the differences stand out if you know what to look for.
Gary- Top
Hi Gary,Frank,
Gary
I am I correct in assuming the 1963 had the no hole lock and the small 1/4" hole lock. These are the only two locks from the 63 M/Y and the boot came along during the 63 model run.- Top
Timothy,
People who have studied this question believe that the no-hole lock was likely used up thru the end of Dec, 1962, at which time the 1/4" weep hole lock appeared. But I'm sure there are examples of the 1/4 weep hole lock on cars earlier than Jan 1, 1963, and examples of the no-hole lock after Jan 1, so there was almost certainly no step-function change-over date.
And yes, the rubber protective boot came along later in the '63 model year; I think around March 15, IIRC according to the TIM&JG. Prior to that date, the foam rubber anti-rattle pad was used. As far as I know LIC is the sole maker of a repro anti-rattle pad, but that repro needs to be modified since the die-cut process that LIC uses to make their repro pad does not allow for the beveled edge that is believed to have been present on the GM pad.
Gary- Top
Timothy,
Gary
Thanks Gary,
Now I remember that anti rattle pad we discussed a few years ago..- Top
Timothy,
I'm still looking for an NOS anti-rattle pad or for an installed original pad oin mint condition from a very low mileage, always garaged '63. I have collected several original '63 tire locks that still have the original GM pad installed, and I've see photos of several other '63 locks, but those pads are all in poor condition and it's impossible to know what they looked like when new. So, to keep my research files from expanding any more, I'm not seeking photos of any more anti-rattle pads in poor condition, but I'm still looking for images of that elusive original GM lock with pad in virgin condition. My main interest is determining how much the pad overhangs on two sides. The repro anti-rattle from LIC is substantially wider than the lock, so there's a lot of overhang on two sides. I've never seen that overhang on a GM pad, but the overhang is likely to be worn away with time and exposure to the elements, so assessing correctness based on old, worn anti-rattle pads is not consistent with high quality research.
Gary- Top
