I recently purchased a 66 coupe with NOM. (3904351 1967 block). The car has all of the prerequisite 427/425 items, except that I cannot verify that it had K66 because it now has a Pertronics setup installed in the tach drive distributor ( no tag on distributor), the K66 harness and amp are gone, and most unfortunately, there was previous body damage to the left front corner/inner fender well so no amp mounting holes are present, nor would be expected.
It DOES have the following clue: The pink wire from the ignition switch to the coil + side terminates with a factory plastic connector just ahead of the firewall. The coil side of this connector has a white resistor wire plugged into it. The white wire runs for about 3 inches, and was then clipped off and routed to an aftermarket ballast resistor. A wire from the other side of the resistor continues on to the coil. The ballast resistor evidently was installed because the primary resistance of the installed coil is less than that called for in the Pertronics manual that I viewed on line. I know that K66 cars did not use a ballast resistor.
My question is this: Did NON K66 equipped cars have the BLACK PLASTIC, PINK WIRE TO WHITE RESISTANCE WIRE CONNECTOR, or did the pink wire go directly to the ballast resistor that was installed on NON K66 cars? My wiring diagram seems to indicate that the connector in question would have only be present on K66 equipped cars. It shows this connector with K66, but appears to show the pink wire from the ignition switch going straight to the factory ballast resistor on non K66.
Forgive my inability to describe the issue succinctly, and thanks in advance for your expertise.
It sounds like you have the right stuff.
on a '67. Fortunately, they used a existing bolt to mount the ballast and didn't disturb the dimple with a drill.
