1956 survey for a possible Restorer article - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1916
    Hi all;
    I am considering an article on 1956 engine sequence numbers as they relate to VIN numbers, and possibly casting dates as well.
    To that end, I would appreciate it if anyone that owns an original 56 Corvette would please send me the following information.
    VIN number:
    Engine Sequence Number: (the seven digits stamped on the engine pad before the engine suffix code)
    Engine block casting date:
    I have about 45 entries already from Mike Hunt's 56 data that he sent me many years ago.
    You can post your data here or send in to me in a private message or email. My email address is emccomas57@gmail.com.
    Many thanks in advance for all of your consideration.
    Ed
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: 1956 survey for a possible Restorer article
    Ed, That's a great plan.......
    I don't have a original '56 here, but here's a bump.
    Rich
    • Mark S.
      • July 31, 1983
      • 655
      Ed:
      My 4200 56 should be in Mike's data. Good luck with the article!
      Mark
      • Edward M.
        • November 1, 1985
        • 1916
        OK, a clarification. I do not have all of Mike Hunt's data.So if you have a 56, please tell me what the VIN is, the engine sequence number is, and the block casting date.I do not have this data for car 4200. I would like to have it.Thanks.
