Ok, so I have my trailing arms back in and had previously completely rebuilt the rear suspension. I restored my original leaf spring which appeared to be fine. Per the assembly manual, I'm trying to make sure that the ride height is correct, it specifically has you check dimension D, before torqueing the front trailing arm bolts. Dimension D is the difference between the centerline of the two ends of the control arm. I've also pulled the car in and out of the garage and up and down the driveway to get the suspension back in shape after having the car on jack stands. I'm not so concerned about dimension D being per spec since the car is old and not outfitted per original specs.
My concern is that the left and right measurements differ. Dimension D on the left is 2 3/8 and right is 2 5/8. Also, when I measure from the top of the tire to the opening of the wheel well at about the tire centerline right side is about 5/8" higher on the right. I know the leaf spring bolt can make a difference in ride height and have the correct length ones and simply tightened the bolt until it lined up with the cotter pin hole. The two bolts appear to have their nuts tightened equally and also measured to ensure the bolt is equally tightened.
Finally my questions. Should I be concerned with the difference from left to right or simply attribute it to the car being old and probably having someone in the driver seat much more than the passenger seat or some such thing? Or perhaps the front suspension is causing the difference since I haven't done anything to the front suspension yet and I'm sure the bushings and perhaps springs are wore out. Or should I attempt to get the two sides equal by making adjustments to the leaf spring bolt? I'm not even sure this is possible since it can't be adjusted too much and still line up for the cotter pin. Anyone know about how much difference in ride height turning the bolt can make - is it even significant?
Goal is to get the trailing arms torqued and then have the rear aligned.
Thanks in advance,
Jack
Thanks in advance,
Jack
