I'll be starting the process of doing a frame-off restoration on my 67 small block coupe in the coming weeks, and I'm looking for input on possible suspension improvements / suggestions I can do to make the car handle better. The car won't be raced, but I'd like to make the car handle as good as possible for some spirited driving. Other than making permanent changes to an otherwise stock vehicle, what can be done to make the C2 suspension perform better? Opinions on stock rubber versus polyurethane bushings on the a-arms? Aftermarket a-arms to improve suspension geometry? When I bought the car 15+ years ago it had a sway bar on the rear, which I removed since it's a small block car. Any thoughts on adding a rear sway bar for street driving?
Comments on offset trailing arms? Any expereinces, good or bad, on using these? Thanks for any help or suggestions you can give me.
Similar to straight axles you could help the steering with the right foot. Have fun. Steve
