1970 Body Mount Fastener Hardware Finish - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    For a 1970, the bolts are plated but I wasn't sure on the finish of the lock washers and thick washer? Thanks for any help.
    Bill
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • William H.
    • January 1, 2006
    • 209
    Re: 1970 Body Mount Fastner Hardware Finish
    Can anyone help me here with your expertise? Thanks much!
    Bill Hyndman
      • 3415
      • Rich C.
        • January 1, 1994
        • 383
        From the info I have, the lock washer #103228 is phosphate plated.
        1973 LS-4 454 coupe owned 25 years
        1996 LT-4 CE coupe
        Long Trail Ale-currently on tap!
        • Rich C.
          • January 1, 1994
          • 383
          That 7/16 lock washer is used on the brake caliper mounting, rear shock upper mounting, lower control arm, and a few other spots.
          1996 LT-4 CE coupe
          • Gary B.
            • February 1, 1997
            • 6979
            Bill
            Bill,
            Can you check the part number for the lock washers in the '70 AIM?
            Gary
            • Gary B.
              • February 1, 1997
              • 6979
              Rich,
              Are you sure that part number is not 103328?
              Gary
              • Rich C.
                • January 1, 1994
                • 383
                Originally posted by Gary Beaupre (28818)
                Rich,
                Gary
                Yup, typo, sorry!
                1996 LT-4 CE coupe
                • Gary B.
                  • February 1, 1997
                  • 6979
                  Yup, typo, sorry!
                  Rich,
                  In that case I have notes for GM # 103328 lock washer that say the GM engineering drawing notes the following: "Carbon Steel SAE 1060 or Equivalent 38-46 HRC. Finish plain". I think the dark gray color on those washers comes from the heat treatment required for the 38-46 HRC hardness spec. I believe that all GM locks washers with part numbers 103xxx, such as 103319, 103320, 1033321, 103328, 103329, 103330, have a similar finish appearance.
                  Gary
                    • 3415
                    Hi Bill,
                    I tried to send you a pm today but was unable because of your 'box' being full.
                    I'll try again in a couple of days.
