Just read a article on Prototype EX 122. It said the car was rebodied in 1955. Wasn't the 53-55 bodies identical? I also thought the orginal hub caps on the 53 were without spinners until 1954.
Ex122
Re: Ex122
They looked the same but as production progressed from the first bodies in '53 to the later ones in '54 to '55 the construction of the bodies changed from mostly hand laid panels to press molded. It's very easy to tell an early body from a late one.
The very first few Corvettes assembled at Flint were shown in photos with the full wheel covers used on the Bel Air car as the Corvette covers were not yet available at the time. Once the Corvette wheel covers were available they all had the two knock off bars '53 through '55. In the mid '70s GM reissued these covers for sale through the Chevy parts departments. These didn't have the knock off bars or indents for mounting them due to federal regulations about such dangerous things being put on cars. I think that these bureaucrats saw Ben Hur a few too many times. There was someone who developed tooling to indent these reissue caps to accept repro knock off ears so they would appear original.
Tom- Top
Re: Ex122
all 53's where hand laid cloth - the bodies are thin - almost see thru
Here is a video showing how the 53 where built
into 53 some parts where changed over to press molded - mostly doors, hoods, rockers,
I am currently doing 1953 #201 - the car has a cloth tub and floor and tunnel but has press molded rockers, core support, upper dash, doors, hood and trunk.
There are some production differences as well
53's body mounts behind the seats are not exposed
54 and 55 are exposed.
53 dash has a hood pull metal tab riveted to the LH side of the dash.
53's the hinge pillars are not drilled for the door hinge bolt holes.....
Visually exterior wise they look the same
I am also recreating a VERY accurate replica of EX 122 Motorama car
The Kerbeck car is NOT EX 122.1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
Re: Ex122
Mr. Sherman, I think you have to make a decision on your "VERY accurate replica of EX 122 Motorama car" and decide which car you would like to build. The Kerbeck car IS EX 122, designated and titled as such on the day Russ Sanders purchased it. It was, indeed, 1 of 1 built by GM, right
up to when Kerbeck made it a hermaphrodite, or worse. It is NOT the Motorama car; that designator is reserved for EX 52.- Top
Re: Ex122
Neat project! Are you building from scratch of from an existing car?
If you read this link below it almost appears Kerbeck is claiming the car is EX 122. Are you saying its not? Was the real EX 122 destroyed?
Mike- Top
Re: Ex122
Chris,
Mike- Top
Re: Ex122
up to when Kerbeck made it a hermaphrodite, or worse. It is NOT the Motorama car; that designator is reserved for EX 52.1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Re: Ex122
Chris, the designator "EX 122" does NOT exist until that day in 1956 when Russ purchased the car, with an ENTIRE 1955 body, most likely from 1 of the 2 late 1955 3 spd cars whose chassis were used for the #5 and #6 Sebring cars in 1956. The designator EX was to call attention that it was NOT a production car. A minor dustup occurred between GM and Michigan over that very thing and was solved by mail. It is also probable that the OTHER late '55 body was used to reclaim Eng. #5951's chassis into a "special proving ground demonstrator" that, later when it was SOLD, was designated EX 87, now residing in the Palm Springs area with the couple that has owned it since 1968, Kerbeck's car is EX 122, as built for Russell Sanders, Chevy's Chief Chassis Engineer (with repairs on all four corners when his daughter made contact, on ice, with another car in an intersection.- Top
Re: Ex122
In addition to those differences Chris identified there are others. The most important of which in this case is that the passenger side inner fender panel is considerably different in order to fit the 12V battery in with the wider V8 engine.- Top
Re: Ex122
Yes, the Kerbeck car IS EX122, as long as it is directly in line with Russ Sanders and Jack Ingle's car, but that lineage goes back to VIN 002, which was Engineering Car #3951 and became EX 122 when it was re-built the last time, just before Mr. Sanders bought it. This is indesputable, as a copy from a page of a Chevrolet Log Book shows EX122/ Engineering #3951 being sold to R. Sanders.
Mr. Sherman, your premise is just simply wrong. The Motorama car, car #852, VIN EX-52 was scrapped. It was stripped and gutted and the body was burned on Nov. 6, 1953 at the Proving Grounds. The frame was rebuilt, modified and lengthened for use as the 1954 Motorama Corvette Nomad Station Wagon Show Car #857. All this info and more is in the summer 1993 The Corvette Restorer Magazine, Vol 20 Number 1 by John Amgwert, in an article named "The Earliest Corvettes". It is the greatest and best Corvette article ever written.
I do wish you well on your super neat project Mr. Sherman, I hope I get to see it some day.
Jim- Top
Re: Ex122
This 10 year old Hemmings article backs up the story that Jim mentioned about the '53 Motorama car's body burn tested at the proving grounds and the frame used for the '54 Nomad dream car.
This is all interesting stuff. The Sanders letter shown below apparently contains some incorrect information?
Mike- Top
Re: Ex122
- Top
