Is this a corvette motor - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    I'm trying to id a motor I have found. I am told it is from a Corvette.
    The engine stamp says FI2IIHT.
    Also on the ledge is this 6111308 serial number.
    Also the engine code is 3858174.
    Having trouble with my usual charts.
    Anyone want to jump in and help with this?
    Any info would be helpful.
  • Mike E.
    • February 28, 1975
    • 5134
    Re: Is this a corvette motor
    350 hp manual transmission engine from 66 #11308. Unless a restamp, a correct original Corvette motor.
    • David H.
      • November 11, 2009
      • 777
      Thanks Mike.
      May I ask where you found this info please?
      • Mike E.
        • February 28, 1975
        • 5134
        Inside my head. 41 years of playing with Corvettes will do that to you. The NCRS spec guide would contain that info, I'm pretty sure.
        • David H.
          • November 11, 2009
          • 777
          Mike, I sincerely appreciate the fact that this information is "in your head", however I would really like to be able to see it in writing somewhere.
          Is the book you speak of the one in the NCRS store? NCRS Corvette Pocket Specifications Guide 1953-1967.
          • John D.
            • December 1, 1979
            • 5507
            David, I believe the pocket spec guides are available for various years. I have about 5 or 6 and have them spread all around the shop and house as people think I am supposed to know all this stuff. Stuff was not my first word choice. LOL John
            • Joe R.
              • July 31, 1976
              • 4547
              David,
              The information you seek is in Volume Sixteen Number One Summer 1989 on page 60. It's the 1953-1972 Corvette Specifications Guide. If you were a member at the time you received one in the mail. They can be found from time to time on E-babe! The pocket guide is a condensed version of that "Restorer".
              JR
              • Donald H.
                • November 2, 2009
                • 2580
                You can find a lot of good books on the NCRS website. The following link is to the website book section. the 1953-1967 Corvette Specifications Guide is on page 3 of the website book section.
                Explore the National Corvette Restorers Society (NCRS) shop for a variety of Corvette restoration resources and memorabilia. Shop for essential guides, manuals, and collectibles designed for Corvette enthusiasts and restorers to enhance their knowledge and passion for classic Corvettes.
                Don Harris
                Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
                • Page C.
                  • February 1, 1979
                  • 802
                  Hi David,
                  It is in fact as others have said a 1966 327/350 engine. Suggest posting this in the C2 NCRS Orphan Documents & Stamped Parts Forum. Just go to the NCRS forums, scroll down to the Orphan Documents & Stamped Parts C2 section and add it to the 7 pages of vin # C2 related parts missing from original corvettes. There has been some success in reuniting some lost the parts.
                  • Dan A.
                    • May 31, 1974
                    • 1074
                    Just a point of clarification. The number 3858174 from your photo number 3 you describe as a code. That is incorrect, it is not a code. The correct terminology for that set of numbers is casting number.
                    • David H.
                      • November 11, 2009
                      • 777
                      Anyone happen to have a digital copy of this page available to post?
                      Thanks for all your replies.
                      • David H.
                        • November 11, 2009
                        • 777
                        OK, so I have found the HT code for the '66 Corvette motor. Signifies a 327/350hp high lift cam, 4 speed L79 engine.
                        The F is for flint plant,
                        I2II is for Dec. 11th, 1966 determined by the 3858174 "casting number".
                        But the serial number of 6111308 doesn't make sense.
                        Anyone want to comment on this number and what it might mean?
                        • Dan A.
                          • May 31, 1974
                          • 1074
                          174 blocks were a one model year casting used in the 1966 model year, you have that correct. From the build date you provide this engine was built Dec 11/65 not Dec of 1966, provided the block has a casting date prior to the build date in 1965. So what is the casting date?
                          Car 11308 was built approximately January 17-18/66.
                          • Donald H.
                            • November 2, 2009
                            • 2580
                            The full VIN would have been 194376S111308 if it came out of a Coupe, or 194676S111308. The engine pad was stamped with a VIN "derivative" 6111308. The 6 for 66 and the 111308 for the last 6 digits of the VIN.
                            Don Harris
                            • Mike E.
                              • February 28, 1975
                              • 5134
                              Actually, the first "1" was simply a spacer. There were not 111,000+ 66's made.
