1969 front clip install - NCRS Discussion Boards
  • Roger D.
    • June 3, 2014
    • 180
    Can someone tell me if the stingray fender emblem is installed after the front clip is set.
    Thank you
    Roger
  • Russ S.
    • April 30, 1982
    • 2161
    Re: 1969 front clip install
    It would have to be installed after front clip install or it would be covered with paint.
    • Roger D.
      • June 3, 2014
      • 180
      Thanks Russ , I was hoping that was the answer. While doing a mock up of my front clip install I noticed I could not get the drivers side to come back far enough to line up the plenum extension. I noticed the emblem was pushed out a little and had a very slight bend. I believe it was catching on the plenum so I removed the emblem to try again when I get some help.
      Thank you
      Roger
