1969 427 thermostat housing question - NCRS Discussion Boards
  • Bill N.
    Infrequent User
    • September 30, 2014
    • 10
    I'm looking for an OEM or NOS housing to replace a reproduction on my '69 427/390. I've got the part number but I'm wondering if the housings were date coded. I'd appreciate any information. Thanks!
    • 43193
    Re: 1969 427 thermostat housing question
    Bill------
    I don't think that any of the original GM #3877660 thermostat housings had any sort of date code. Some of the later SERVICE examples have some embossments that some might regard as a date code but I do not think they are such.
    • Bill N.
      Infrequent User
      • 10
      Hi Joe,
      Thanks for the info. Mine currently doesn't have any embossing except for the part number on top, not on the flange. I know it was replaced in 2000 according to invoices that came with the car. I'm sure it was replaced with a reproduction. The cost of the replacement was only $20 back then. I do want things to be correct but I'm wondering if the NOS examples online are service replacements vs. the real deal. Here's what I've found: http://www.ebay.com/itm/NOS-66-67-68...p2054897.l4275
      Bill
        • 43193
        Hi Joe,
        Bill
        Bill------
        Although I can't see all of it in the photo, I can see enough of it to be pretty sure this is a later GM SERVICE piece. It's not configured like the 3877660 housing circa 1969. It's possible that this configuration was used in PRODUCTION for later C3's but not for 1969.
        • Bill N.
          Infrequent User
          • 10
          Thank you, Joe. This is what I need to know. I'll pass on it and keep looking. i appreciate the help. If you could send me to someone you know of I'd appreciate that, too!
          • Peter S.
            • March 28, 2012
            • 327
            Hi Bill,
            This one looks pretty nice: http://www.ebay.com/itm/1966-74-CHEV...59553b&vxp=mtr
            The 660 was used on alot of motors, you shouldn't have much of a problem finding a good, original example.
              • 43193
              Bill------
              One word of caution: many judges consider that all big blocks had the part number of the thermostat housing on the flange rather than the neck. I don't believe that. It may well be that many or, even, most big blocks used a thermostat housing with the part number on the flange but I really don't think that ALL were that way. In any event, to be "safe" from what I believe is a misconception, you might want to find a 3877660 with the part number on the flange. The problem is that because of this big block-related misconception, these housings usually sell for much more money. Nevertheless, if yo look for awhile, you should be able to find one at a reasonable price. These things are anything but rare.
                The GM drawing for the 660 thermostat housing leaves the choice of the part number location to the supplier/manufacturer; they could put the number anywhere they liked as long as it could be inspected.
                • Peter S.
                  • March 28, 2012
                  • 327
                  Hi John,
                  Do you have a copy of that drawing that you are willing to share? It has seemed (and I have absolutely no scientific evidence to back this up) that the part number location varied based off of casting date rather than big block vs. small block?
                    Originally posted by Peter Stout (54749)
                    Hi John,
                    Hi, Peter -
                    See 660 drawing below, with notation at the bottom for "optional" location of manufacturer's ID. The manufacturer of the 660 housing had no clue what the final application would be - he just shipped "X" number to each engine plant. If you need a much higher resolution drawing, I can supply it.
                    • Peter S.
                      • March 28, 2012
                      • 327
                      Hi, Peter -
                      [ATTACH=CONFIG]60424[/ATTACH]
                      Thanks John! Another question for you and/or Joe: Who creates/designs the part? Is that a GM drawing which gets sent out to a fabricator?
                      Lastly, I assume the triangle with the "ADC" is the manufacturer's mark. Were there multiple manufacturer's because I have seen housings without (at least to my inspection) any manufacturer's mark.
                        • 43193
                        Peter-------
                        A part and drawing like this one was designed and drawn by GM. The parts manufacturer had to manufacture a part which conformed to the drawing and specs.
                        There were almost certainly at least two manufacturers of this part. Most GM part drawings require that a manufacturer's ID appear on the part. However, I've seen quite a few parts over the years that didn't appear to have a manufacturer's ID on them. Usually, I think that parts manufactured by internal GM parts manufacturing operations of the day didn't either require or receive manufacturer's ID. But, I've seen parts that I highly doubt were manufactured by internal GM operations that did not have manufacturer;s ID's on them.
                        • Peter S.
                          • March 28, 2012
                          • 327
                          Joe and John--
                          Thank you both. Your knowledge is enlightening, thank you for sharing.
