C2 Gas Tank Anti-squeak Pad question - NCRS Discussion Boards
  • Wayne Y.
    • March 10, 2015
    • 41
    http://www.gastanks.com/images/MYGTI-16.jpg In other on-line resources, it shows those same Anti-rattle/anti-squeak Pads as being 4-pieces (1 long one for the forward side of the tank, and 3 pieces for the rearward/sending unit side of the tank). Example here: http://www.parts123.com/corvettecent...050b&ukey=1797
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: C2 Gas Tank Anti-squeak Pad question
    Wayne, You may want to refer to your AIM for the answer. The 67 AIM shows 4 pieces of anti squeak material. I've also included a photo of my original tank with the material applied. The original material was about .100 thick. The front strip was 2" wide and the 3 rear pieces were 1-1/2" wide. The material is a heavily impregnated "felt".
    I doubt these are judged....... due to location.
    • Wayne Y.
      • March 10, 2015
      • 41
      Thanks Stephen - not sure why I didn't think that would be in the AIM...but you're right. The 63 AIM shows a 4 piece set-up as well, just like your 67 tank photo. Thx!
      • Chuck S.
        • June 30, 1991
        • 184
        I replaced my tank because it had rusted from moisture absorbed by the original pads which looked like a felt type material. I fabricated my replacement pads from rubber.
        When I examined my original (63,000 mile) tank, it was clear that it had rusted from the outside, in the location of the pads.
        • Bill W.
          • March 1, 1980
          • 2000
          Chuck I always use rubber roofing material for the same reason .
          • Mike E.
            • June 24, 2012
            • 920
            I didn't realize this and bought the repo part from one of the larger Corvette parts supplier. It turned out the part was roofing tar paper cut into strips. On one side it even had the gray lines that one can use to line up the courses of shingles.
            Mike
            • Dennis O.
              • December 1, 1988
              • 438
              And I thought I was the only one to take the cheap way out. When I re-installed the tank on my '70, I noticed that the anti-squeak looked an awful lot like a used version of the roll of tar-paper I had sitting in the corner. Worked fine.
              • Gary B.
                • February 1, 1997
                • 6979
                Doesn't roofing felt come in different weights/thicknesses? Is it available in a thickness that is equivalent to the thickness of the original GM material?
                Gary
                • Stephen L.
                  • May 31, 1984
                  • 3148
                  Gary,
                  I went to a local commercial roofer looking for a material close to the original, .100 thick. No luck. I did find some similar material at a local junk yard used on a MOPAR fuel tank in sheet form. That was AFTER I discovered that the Corvette vendors were selling strips of common roofing felt paper.
                  • Larry M.
                    • January 1, 1992
                    • 2688
                    Originally posted by Stephen Lavigne (7553)
                    Gary,
                    Although many folks don't like his customer service very much, DR REBUILD has the thicker and properly cut tar paper/felt. Otherwise buy the HD felt (30# I believe) and use that.
                    Larry
                    • Mike M.
                      • May 31, 1974
                      • 8365
                      i too prefer rubber roofing material as it doesn't hold water which causes the tanks to rust thru from the outside. mike
                      • Allen N.
                        • January 1, 2003
                        • 288
                        I bought and received the Dr. Rebuild pads and they are about 1/32" thick instead of 3/32" thick. Anyone know the best place to get thicker pads or felt that I can cut myself?
                        Allen
                        • Greg W.
                          • February 26, 2015
                          • 141
                          The pads could be judged as I lost a point at a regional because they were to thin. Being a roofer for the past 40 years there are two different thickness of 15# felt and 30# felt and also UL listed 30# felt that is a lot thicker than the regular 30# felt. If one went to a roofing supply Co they would probably cut you a small piece N/C
                          Greg
                          • Gary B.
                            • February 1, 1997
                            • 6979
                            Greg,
                            Do you know the thickness of the UL listed 30# felt?
                            Gary
                            • Greg W.
                              • February 26, 2015
                              • 141
                              Gary, I do not, But I will go up to the shop and may have a old roll, If not Tuesday I will go to the supply house and cut a piece.
                              Greg
