I know that timing issues have been discussed in great length but I could not find any similar issues to mine in the archives.
i am tuning my recent acquistion a 1967 small block 300hp which runs well and starts well but I was shocked to see the initial timing is 32 degrees. The timing marks on the balancer and tab line up at TDC so I assume the distributor gear must be out 180 degrees which was probably done when the pertronix conversion was done.
Someone told me there is about 27 degrees difference if the gear is out 180 degrees so doing the the math my initial timing is really about 5 degrees which is close to factory specs. Does this seem logical or is there any other reason for my initial timing reading of 32 degrees?
My total timing is close to 60 degrees.
Lorne
Lorne
