72 Exhaust Tip Gaps - NCRS Discussion Boards
72 Exhaust Tip Gaps
  • Rey S.
    • April 1, 1995
    • 277
    72 Exhaust Tip Gaps
    OK ---- I have one more exhaust tip question ( sorry for being a pest but I am not finding anything in the AIM ). What should the gap be between the top of the 70-73 ( rectangular) exhaustst tips and the bezel as measured at the outer edge of the bezel ? Is it the same as the side to side gaps ?
    Thanks for all your help !
  • Mark C.
    • March 28, 2007
    • 21
    Re: 72 Exhaust Tip Gaps
    Put new mufflers on. Someone had switched tips in the past to opposite side so I corrected everything when I rebuilt suspension. Here's a couple pics. Basically even on top and both sides.
    • Harmon C.
      • August 31, 1994
      • 3228
      I center the tips in the bezel about 3/4" on the top but make sure both sides are the same. I have spent four hours on this job making adjustments.
      Lyle
        • 3415
        Hi Rey,
        How about this?
        Looks to be centered side to side in the bezel and then about the same dimension from the top of the bezel.
        • Harmon C.
          • August 31, 1994
          • 3228
          The tips on Allen's 71 look perfect.
          Lyle
            • 3415
            Hi Lyle,
            I wish that convertible belonged to me, but alas, it doesn't.
            I did get to help judge the Operations Section on it though!
            It's a very striking color and car!
