Gentlemen;
Just worked on my motor with a friend, and changed out a completely blocked vacuum advance unit for a new one; from Long Island Corvette. Also adjusted the timing (10deg), and changed the sparks to NOS AC45 units.
Since the works, my engine is knocking on hard acceleration, and I cannot adjust my idle at the carb, with the vacuum connected. Idle stays at 950-1000.
Someone suggested to unhook and block the vacuum hose - and this has solved the knocking, and I can now adjust the idle down to 850 range.
NB - We removed the rotor during works & I assume we placed it back in the same position...... Lots of stuff going on & it's confusing. Are there simply adjustments to be made, or perhaps the vacuum advance unit supplied is the wrong application ? I have been told that the 'STANDARD IGNITION' VC181 unit is the proper vacuum advance for my car.
Finally, we adjusted the solid lifters to factory specs on a cold engine. The "clacking" sound is more pronounced now with the engine running. Is this ok ?
Thanks in advance;
Thanks in advance;
