I'll be re-assembling my L-79 distributor this weekend and have an assembly question. In some re-build articles I've read it says to fill the grease well with an absorbent material like gauze or similar, then pack with grease. Is that accurate to pack the cavity with an absorbent material, because I've never done that in the past. I was planning on just filling the grease well with EP grease.
Also, once I've filled the cavity with grease, do I install the plastic seal, then on top of the plastic seal I install the felt washer (impregnated with grease) for the points plate to sit on?
Thanks.
Thanks.
