what is the torque setting for the center bolt on a 65 std. rear spring ?
65 rear spring center bolt
Re: 65 rear spring center bolt
Same words in the '66 shop manual. I'd use up to the torque specified in standard bolt tables for 5/16" fine thread (say 10 ft-lbs). It will probably turn before that. The spring/liner stack should be held together in a C-clamp while tightening center bolt.- Top
