64 steering wheel shake - NCRS Discussion Boards
  • Jim P.
    • January 27, 2014
    • 18
    My 64 steering column shakes when the engine is on fastidle (car is parked).
    The crankshaft andflywheel with pressure & friction plateswere balanced when rebuilt 15 years ago.
    is this somewhat typical and I should justlive with it or should I try replacing / rebuilding the balancer ?
    Thoughts / comments.
    Jim
  • Ed S.
    • August 6, 2014
    • 1377
    Re: 64 steering wheel shake
    Jim, I have a '64 L76 like you. I did not have a steering wheel shake problem, my wheel traveled in and out about 1/4 to 3/8s of an inch - it was like I had a telescoping steering wheel but I don't. The problem was the rag joint - it was totally shot but surprisingly, there was no noticeable issues when the car was being driven, it steered fine. Point is - I think you might have an undetected steering / safety issue that is worth investigating to the nth degree - I would not rest until I identified the cause and determined if it was or was not a safety issue.
    Ed
    • Jim P.
      • January 27, 2014
      • 18
      Ed,
      The rag joint was replaced 15 years ago so I didn't think that would be the problem. I will double check.
      Thanks, Jim
