Men just finished reading John Hinkley and Dukes discussion about the 1969 passenger car timing tab location. My question is... Could the aftermarket chrome ac delco timing cover also be moved 10* ? What would be the simplest most accurate method of checking TDC with the heads on? I will be testing this for 1968 L-79. Can someone give me the part # for a 1968 L-79 harmonic dampener? Not a 300HP dampener! Where might this part # be located? Is there a date code stamped on the dampener? Thanks in advance.
