Correct C-1 radiator support finish - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 660
    What's the correct black paint finish on a 1960 radiator support? Tom Baird's book says gloss black but I don't see the finish specified anywhere else.
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Brad K.
    • August 31, 1990
    • 414
    Re: Correct C-1 radiator support finish
    Because the 58-60 Judging manual specifies the fan shroud to be painted semi-gloss black, I "assumed" the radiator support (to which the shroud is bolted) should be the same. You're correct, the manual does not specify the radiator support. I have never had any judging issues with it. That's not to say that I wouldn't have any in the future! Perhaps Baird's book "assumed" the finish to be gloss because the radiator is gloss....Who knows?
    • Keith R.
      • August 31, 2001
      • 660
      Thanks Brad. I presumed the same thing. I've owned the car since 1987 and when I did a body-off that year, I left the support untouched. It is semi-gloss black but it needs to be re-done. There's a '59 survivor in town and I think that I'll ask the guy working on it what the finish is on that one (if he can tell - it was sitting outside for years!)
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      • Dan H.
        • July 31, 1977
        • 1365
        I believe the support was already installed with hood etc. in place. It should have it's pre install black primer coating, then body primer, body color to some extent, then be painted with engine compartment black out paint to cover all the other coatings.
        Dan
        1964 Red FI Coupe, DUNTOV '09
        • Brad K.
          • August 31, 1990
          • 414
          I've owned this car since 1969 (10 years old) and I re-painted the engine compartment before I even heard about the NCRS or its guidelines....Talking to other survivors is a great idea....good luck.
          • Keith R.
            • August 31, 2001
            • 660
            Probably a good assumption as the support was installed to prevent front end twist early in the assembly process I believe. So, the final engine compartment black-out is the final covering on the radiator support then...
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
