Re: Just How Fast Are C2 Small Blocks?
Just answering the OP's request for stories, plus a bonus video for some people's enjoyment.
Also want to share with the OP what a normally perspirated
327 (well, OK, actually 331) can do when built RIGHT and with parts that work in harmony with each other. Wanna race your ZL1? Say, old chap, did you ever get that thing on the road?
Donny Brass runs a "pure stock" '66 with a 327/350 in PSMCDR in Michigan. He holds the class record, but of course, some cheating always goes on. His car is not streetable (at least in my opinion) since it uses a 4.56 axle ratio. The class allows suspension mods to transfer weight to the rear wheels. and lightening. The camshaft doesn't have to be stock, except for lift and duration at one lift value.....so "cheater" cams can and are used. His engine is WELL blueprinted and built with tight quench, which allows for aggressive spark advance and higher static compression (than advertised, not actual stock values) free from detonation. Probably makes around 400 honest flywheel HP. I believe street slicks are permitted as well, since he does a burnout before his runs.
He hooks perfectly and powershifts all gears, drives like a pro. His best run was 12.838 @ 106.8.
327 (well, OK, actually 331) can do when built RIGHT and with parts that work in harmony with each other. Wanna race your ZL1? Say, old chap, did you ever get that thing on the road?Donny Brass runs a "pure stock" '66 with a 327/350 in PSMCDR in Michigan. He holds the class record, but of course, some cheating always goes on. His car is not streetable (at least in my opinion) since it uses a 4.56 axle ratio. The class allows suspension mods to transfer weight to the rear wheels. and lightening. The camshaft doesn't have to be stock, except for lift and duration at one lift value.....so "cheater" cams can and are used. His engine is WELL blueprinted and built with tight quench, which allows for aggressive spark advance and higher static compression (than advertised, not actual stock values) free from detonation. Probably makes around 400 honest flywheel HP. I believe street slicks are permitted as well, since he does a burnout before his runs.
