Re: C6 Clutch and Brake Fluid
Don,
Over on CF the Prestone DOT4 is the most popularly recommended replacement:
http://www.autozone.com/brake-and-po...id/433371_0_0/
Here is a good thread:
Watch the video.
Remember, it takes 7 empty-and-fill cycles to say you've flushed the whole system. At 30-40 clutch pedal pumps per cycle you're looking at a lot of leg work. However, it really does not take a lot of fluid each time. I use a large syringe to empty it ( I have a good supply
), and make a linear hole from the edge to center of the metallic seal on the top of the fluid before dispensing. This does help minimize the splashing of the fluid, but I still hold a couple of rags around the reservoir.
Don,
Watch the video.
