Frank Tetro(Harbor Auto Restoration in FL) and I were talking this morning about Half Shaft Outer Flange and Inner Cap Bolts which attach the U-Joint to the Differential Flange.
I told him I'd take some pictures of the Bolts removed from this '67 I have here. I sent them to him. He got me curious as we had some confusion about bolt usage, so I dug in....
The Outers(Flange to the TA axle) are Grade 8, circle surrounded by 6 lines. (300M Grade)
The Inners on this car appear to me to be original. They are RBW, 3 lines, Grade 5(280M). The AIM UPC L36 Sheet A12 calls out Part# 180126.
The JG on Page 208....."Attachment to the differential yokes is via forged steel caps secured with cadmium or zinc plated hex-head Grade 8 bolts with lock washers, typically with an A headmark."
Firstly, most Grade 8 bolts I've encountered are not zinc plated but typically black phosphate.
Secondly, I did a little research and found the 180126 part# referenced in the Master Parts Book X-164001 September 1963
The lower right of the above page describes bolt grades. Default with no special "otherwise" means the bolts are 280M(Grade 5-3 Lines)
The Next Page of the above link (Here) shows the 180126 as a 3/8"-16 x 1 1/2" bolt..............Default is 280M (Grade 5).
So there appears to be a hiccup in the 1967 JG ???
Just some more information I always learn about these cars and their parts.
Rich
Rich
