1967 Big Block Outer Flange and Inner Half Shaft Cap Bolts - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: 1967 Big Block Outer Flange and Inner Half Shaft Cap Bolts
    After all of this research I just had to use the originals and not the repro grade 8's.
    Back from the plater ....
      [ATTACH=CONFIG]61177[/ATTACH][ATTACH=CONFIG]61178[/ATTACH][ATTACH=CONFIG]61179[/ATTACH]
      Rich-------
      I hope the plater properly annealed these bolts after the plating.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        #18
        Joe, I'll ask again but I recall he does a bake after plating.
        Rich
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          #19
          Another bolt in question as per finish in the JG.
          There are 4 bolts holding the strut bar bracket to the differential, part# 454905. This is a 3/8-16 x 3/4" bolt 300M (Grade 8).
          I have found this car had 3 Grade 5's and one Grade 8. The Grade 8 has a circle with 6 radial lines. It appears to be originally black phosphate.
          (insert photo here later)
          The description in the P&A Standard Parts Catalogue states that for 300M bolts......
          "Those showing 300M are Chrome Nickel Steel...."
          What is the color of this bolt as specified? I cannot get a definitive answer through my research.
          Reproductions are dichromate(gold) in color and I don't think this is correct. I need to get the proper Grade 8 bolts for proper specified strength for this bracket.
          I believe the color should be as commonly seen as a black oxide/phosphate finish as other Grade 8 bolts of the era were. The JG specifies cadmium/zinc(silver) finish which I think may be erroneous.
          Rich
          • Rich P.
            • January 12, 2009
            • 1361
            #20
            Rich, contrary to what you think they are bright zinc grade 8. That is TFP. 67 headmarkings are WB, AS (large and small font), S (2 different configurations) and a few more. Hope this helps. I can post pictures if desired and if you need right ones I have them. Rich.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11302
              #21
              Thanks Rich, That's good info. Are they 6 radial lines? Pictures would be great.
              I'll drop you a PM too.
              Rich
              edit...I just wire-wheeled that one I have here. It was painted with heavy black paint and after cleaning I see there is the "WB" and six lines.
