Can someone make a solid recommendation to recurve my LS-5 distributor to factory specs? Appreciate any suggestions for guys who specialize in our cars. Thanks much! Pat
Distributor Recurve Service
Re: Distributor Recurve Service
Lars Grimsrud
(303) 323-5745
lars.grimsrud@lmco.com
He just did my '63 distributor two months ago. Fast turn around, reasonably priced and very good at what he does !
- Top
Bill Clupper. He's available through contact info here on the board.Vice-Chairman (West), Michigan Chapter NCRS
Assuming it's set up with a more performance oriented spark advance map, why would you want to go back to OE specs? The OE centrifugal curve is too short and lazy, and the VAC is lazy and set up ported. The map is set up for emission control, not performance or fuel economy.
About 30 centrifugal all in by 3000-3500, 8-10 initial and a B26 VAC set up for full time vacuum advance would be pretty close to ideal.
Duke- Top
Very true. The stock curve is very conservative. After I got my distributor back from Lars I now have my initial timing at 16* on my stock 250hp '63 coupe...way above specs.
The car has much snappier response and no bad effects on economy and idles like a dream.- Top
Frank, so you are running approx 30* idle timing with the V/A connected?- Top
You may want to print these out, good reading.
http://www.lbfun.com/warehouse/tech_...101Article.pdf
http://www.lbfun.com/warehouse/tech_..._explained.pdf
http://www.lbfun.com/warehouse/tech_...ance_Specs.pdf
http://www.lbfun.com/warehouse/tech_...t%20Timing.pdf- Top
Attached Files- Top
