Has anyone had this problem,every year when I take the 1960 out of storage the rear break lites don't work.this means a new switch,the ones i get look just like the orig. but the following season same failure comes up,the switch contacts remain in the open position and fail to put power to the rear tailites,I remove the switch,spray a cleaner/lite lube and hand operate the plunger on the switch ,and bingo it begins to work.Is their a replacement switch that would function properly year after year? I have adjusted the plunger all the way out so that it is like a hair trigger to activate.
any thoughts/suggestions....? Francis
