I'm having some issues with trying to properly adjust each door glass and was hoping someone might have some suggestions to help me along. The car has power windows and I'm using the AIM & GM Manual, the glass is the original glass and the weather strip is from Corvette Rubber Company.
My issue with the drivers side is that it seems like the glass is "dragging" on the A pillar strip as the window is powered up. This leaves a noticeable gap between the front upper corner of the glass and the T-top side seal, also the aft vertical edge of the glass is no longer parallel with the B pillar when it's up. The glass actually rotates counter clockwise as it's dragging against the A pillar weather strip. If I crack the door open and power the glass up then all is good and it fits fine when I close the door. Then if I adjust the glass clockwise to compensate for it's movement against the A pillar it seals better all around when powered up with the door closed however the upper aft corner of the glass then contacts the B pillar and T-top latch adjustment plate when I open and close the door so that is not a solution either.
I can't seem to find a happy medium here, either there is a gap on the top front edge of the glass or the top aft corner is hitting the B pillar and T-top latch adjustment plate. With the glass a couple inches down from the up-stops it does seem sort of "loose" like you can grab it and rotate it back and forth a bit but I'm not sure if that is acceptable or not.
Even though I've had both door mechanisms out and inspected them and felt that everything was okay I thought I'd try to adjust the passenger side. My theory is that if something is worn that the passenger side should have far less wear so I might get lucky. Well that side seems to have adjusted up a lot better(not perfect yet but much better) so now I'm wondering if some things are too badly worn on the drivers side to allow for proper adjustment.
Does anyone have any ideas here for me? Like I say the drivers side components seemed okay when I had it all apart but maybe I missed something or didn't realize how tight it has to be... Are there any "common wear" items that I should have replaced? I really didn't want to replace any original parts with repop parts unless I have too.
Also are there any good products out there to soften rubber to maybe help reduce the "dragging" that I'm having. I remember a GM product called Silicone Emulsion years ago that was used to preserve weather strip. Would that be something to try or is there a better product these days?
Sorry for the long winded story but I hope it better explains my issue here. Thanks guys.
